Eddieeee
Aug 29, 2021Follower
Nighthawk Tri-Band AX12
Man, I am feeling soooo defeated that I cant get this to perform the way it should. Random drop of signal and just alround performance just sux. 500 bucks too, I am soo done with netgear!!!!
- psychopomp123Luminary
No issues with my RAX200/AX12, probably the best router I've ever used.
- DarrenMSr. NETGEAR Moderator
Hello Eddieeee
Can you give some more detail on the issues that you see? Have you made sure to use the latest firmware? Have you tried to adjust the wireless channels?
DarrenM
