Retired_Member's avatar
Retired_Member
Sep 28, 2025
Nighthawk WIFI 6 Router RAX70 - with sky broadband
Hi
can you advise if Nighthawk WIFI 6 Router RAX70 - with sky broadband full fibre with an open reach box as got sky SR213 (white router) a month ago and the signal strength isn’t very good will this be a good alternative router?
  • FURRYe38's avatar
    Should work. You'll need to talk to the ISP about any specific configurations needed on the NH router so it can replace the ISP router.
    Or you could use the ISP router, disable the wifi routers and net up the RAX router for wireless AP mode as an alternative configuration.
  • plemans's avatar
    The RAX70 is a pretty solid router. Most 3rd party routers are going to be better than ISP supplied devices. But I always advise people to order from somewhere with a good return policy.
