Lreye90
Oct 15, 2020Follower
Nighthawk WiFi
I have got this router nighthawk ax4 somewhat it connected but doing on the nighthawk app says it not connected or issues with Netgear WiFi or not detected tired resetting my own cable modem multiple times some say to do that but didn’t work I literally tried everything and still doesn’t connect plz help
1 Reply
- Christian_RNETGEAR Employee Retired
Hello Lreye90,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
