Redtulips7
Mar 24, 2019Luminary
Nighthawk x10[R9000] To Nighthawk Tri-Band AX12[RAX200]
So I upgrade from R9000 to RAX200 Router, I was hoping to see at least 10% Wi-Fi speed improvement but seen none!!! I got Verizon Fios Gigabit speed but surprise to see no improvement over the previo...
schumaku
Mar 24, 2019Guru - Experienced User
How comes you expect this - because the old was designated AD7200 and the new AX11000? Or simply new == faster?
Unless you have capable Wifi 6 (802.11ax) clients which can bring a massive speed enhancement, the 802.11ac standard implemented on the RAX200 is still the same, and will remain the same, for your existing 802.11ac clients.
Curious where you have acquired your RAX200 btw.
- schumakuMar 24, 2019Guru - Experienced User
Forget one point (as editing after posting is still not possible here in this community section ChristineT Christian_R !) ... of course the RAX200 will allow some more concurrent throughput (by multiple clients) on 5 GHz because of the two radios in this band.
Last, for the future records in the community - which firmware version is in place on your RAX200?
- Redtulips7Mar 24, 2019Luminary
How did I? NGPB Prog. very fast shipping, thx to NG
Now lets talk about Link speed? RAX12 Link speed slower than Nighthawk X10 192mbps Vs 172mbps!!!
Router Firmware Version
V1.0.0.78 - schumakuMar 24, 2019Guru - Experienced User
In a isolated laboratory I would be concerned. In the real wireless world it's not uncommon that the link rate does vary slightly, depending on a zillion of factors. And then again, as I said before ... the risk of jumping on pre-mature technology devices.
