Alphapenguin
Jun 13, 2020Follower
Nighthawk X6S R8000P won't connect to internet
Bought and installed on 27 May 2020 to replace my Spectrum router. I had no problem installing it and and it linked with Spectrum modem with no issues. My iMac desktop is on the ethernet cable from t...
michaelkenward
Jun 14, 2020Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Remember, when restarting things, you have to get the order right.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it connect.
- Turn on computers and rest of network.
