cdoan
Mar 20, 2020Tutor
Nighthawk X6S Tri-band or Nighthawk AX12
Hello guys! My current service is Cox Gigablast Internet w/ a Netgear CM1000. I ran a Nighthawk X6S Tri-Band Wireless Router a couple days ago and now I have the Nighthawk Ax12. Having connecti...
Newfiedrool
Mar 23, 2020Virtuoso
Is this the RAX120 or RAX200.
this will apply to both but I would also recommend you check the support pages too for hot fixes which need to be installed manually.
once you are sure it's up to date then perform a reset using the rear pin hole method. Setup as new with out using a saved config and see how it goes.
