makule's avatar
makule
Tutor
Mar 15, 2020
Nighthawk X6S update timing out
Hello all!  Got a message that the firmware needs updatiing.  Logged to the extender and ran the firmware check but it keeps timing out.  Is the server or website down?  The main router firmware is u...
  • plemans's avatar
    Mar 16, 2020
    You can manually update the firmware. go to negear.com/support/ and you can download the firmware. extract it. Then manually install it.
    I find this method to be the safest for updating firmware, I'd also encourage you to do it over a hardwired connect for best results.
