Davidhere
Jan 18, 2022Aspirant
NightHawk X8 and fibre to the curb
Hi all, 3 years ago I purchased a Netgear Nighthawk X8...an expensive purchase but it worked great. Recently we moved house and our broadband coonection changed from Fibre To The Node to Fibre To Th...
Jan 19, 2022Guru - Experienced User
That model already has built in router and wifi. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
For your model router, Netgear has set up a community forum specifically for the NightHawk Router products. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Thank you.
