aspauld22
Mar 17, 2020Aspirant
Nighthawk XR500 not reconnecting to internet after reboot
So I recently purchased the XR500 Pro Gaming router and an Arris Surfboard SB6190 modem. I have noticed that when I reboot the router (only done in order to clean up some messy cables that were in th...
WestWH
Apr 27, 2020Aspirant
I came across this post while researching this issue. I'm experiencing the same problem with a TP-Link router. Whenever I reboot the router, it does not reconnect using DHCP and i must reboot the SB6190 modem to obtain an IP addrress from the modem. Previously, I had an SB6121 and never had an issue when the router rebooted. Only change is the new SB6190 modem. I'll continue to research for answers and post if I find anything.
Modem: Arris Surfboard SB6190
Router: Archer C9
ISP: Xfinity 200mbps
- microchip8Apr 28, 2020Master
WestWH wrote:I came across this post while researching this issue. I'm experiencing the same problem with a TP-Link router. Whenever I reboot the router, it does not reconnect using DHCP and i must reboot the SB6190 modem to obtain an IP addrress from the modem. Previously, I had an SB6121 and never had an issue when the router rebooted. Only change is the new SB6190 modem. I'll continue to research for answers and post if I find anything.
Router: Archer C9
This forum is for NETGEAR devices only. If you need help for TP-Link, use their forum or ask over at SNBForums
