bauerr7000
Feb 28, 2024Aspirant
nighthawkax5 ax4200 RAX42
cant login, says following: Access Denied Access to the requested page has been denied. Have tried reset and reset password and still gives above message? Thanks for any info?
- Feb 28, 2024
If you updated FW, follow this to correct it:
bauerr7000
Am using this login http://192.168.1.1/start.htm
after enter the login port comes up and after entering login and password it redirects to following:
I have no idea what that is.
Does this mean the router went bad?
