dchadduck
Sep 28, 2022Aspirant
NighthawkRAX54 not connecting after only 3 months. ???? What now??? Thanks
NighthawkRAX54 not connecting after only 3 months. ???? What now??? Thanks Tried different ports. No connection. Modem to computer works fine.
- Sep 28, 2022
Send it back.
Sep 28, 2022Guru - Experienced User
Are there any LED indications on the top of the router?
Factory reset the router by pressing the reset button?
If nothing seems to work to correct the router, I would make contact with NG support and ask about an RMA:
dchadduck
Lights look normal.
Show red for 2.4 Ghz and green for 5 Ghz wifi.
Tried 3 of 4 ports. No difference.
Did all the plug and unplug routine Modem, Router and computer.
Just found the receipt. Costco. They'll take it back with no issues. Guess I order another one. Will see what they have in the store.
