dchadduck
Sep 28, 2022Aspirant
NighthawkRAX54 not connecting after only 3 months. ???? What now??? Thanks
NighthawkRAX54 not connecting after only 3 months. ???? What now??? Thanks Tried different ports. No connection. Modem to computer works fine.
- Sep 28, 2022
Send it back.
Sep 28, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
dchadduck
Don't know how to access Router from computer. It's on 5 Ghz for wifi pre led light.
