SlightyStoupid
Sep 30, 2024Aspirant
Nintendo switch NAT issues RAX45
Recently started having issues with my switch only getting NAT type of D speeds have been fine but can't connect to any online games. this started a week ago and have tried some of the Nintendo port ...
Oct 01, 2024Guru - Experienced User
Armor, Smart Parental Controls or Circle
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
I'd contact Nintendo for help and support information regarding there game products.
SlightyStoupid
Oct 01, 2024Aspirant
Current firmware is v1.0.16.132 on the router
ONT is Adtran 452
i have reset everything and it has done nothing to help with the switch having NAT issues
everything else works fine it is just the switch that i have been having issues with and most of the nintendo
support instructions also have done nothing to help
so next step is me contacting IP and seeing what can be done on there end
- FURRYe38Oct 02, 2024Guru - Experienced User
Ask the ISP about your ONT for sure. Maybe a gateway there which may have a built in router. If so, this would cause a double NAT condition.
