Curly9
Jul 08, 2019Aspirant
No 5ghz rax120
The 5ghz light is on but I can't connect to it or see it any ideas?
aFireInside82
Jul 12, 2019Aspirant
If you have WiFi SmartConnect enabled, you may only see a single SSID for both the 2.4 and 5ghz networks.
The router's "connected devices" gui will show you which devices are connected via wired, 2.4, and 5ghz.
