sammybk
Mar 14, 2023Aspirant
No 5ghz SSID when setting 160mhz channel - RAX50v2
Just opened the box and setup RAX50v2 with Firmware Version V1.1.3.18_2.1.14. On setup no 5Ghz wifi was showing up. I changed the channel size down to 80mhz and it works like a charm. Back t...
Mar 15, 2023Guru - Experienced User
Try changing the channel to the lower 5ghz channels when you have it set to 160hz. See if that helps.
Are you using smart connect.
