RouterQuestions
May 15, 2024Aspirant
No internet access via 2.4ghz or ghz6 bands with RAXE300
Hi all, My router is configured to allow access 2.4Ghz, 5Ghz and 6Ghz bands - I have many devices that can only connect to 2.4Ghz. Multiple times a day, I will notice that my 2.4Ghz devices are ...
May 15, 2024Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Wall outlet?
Who is the ISP?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channel configurations are currently set on the router?
Is Smart Connect enabled or disabled?
RouterQuestions
No FW update is listed as available after factory reset. V.1.0.7.62.
I cannot find the Smart Connect option in the Nighthawk app - but isn't that what condenses everything into one network listing? When I search for WiFi networks I do always see 3 bands/network options.
No modem is being used (regardless, this is unchanged after switching out Xfinity modem). Provider is Burlington Telecom. Wall outlet, yes. Using Cat6 cables.
Channel settings are currently AUTO for 2.4ghz, 44 for 5Ghz and 37(PSC) for 6Ghz
EDIT: I found Smart Connect, it is not enabled.
- FURRYe38May 15, 2024Guru - Experienced User
New FW is listed here:
https://www.netgear.com/support/product/raxe300/#download
Something to try and see.
Factory reset and setup from scratch after loading the FW file.
Yes. Something to enable and try.
EDIT: I found Smart Connect, it is not enabled. Can only check for this on the routers web page.
