RickSwi
Nov 30, 2021Aspirant
No internet cable connected
Hi I just bought a rax40 to update my r6120 I was thinking plug &play but no... By pluggingmy new router I receivedthe err message that no ethernet cable was plug in. However when I put my old r6120...
Dec 02, 2021Guru - Experienced User
Any progress on this?
RickSwi wrote:
Hi
By pluggingmy new router I receivedthe err message that no ethernet cable was plug in. However when I put my old r6120 back everythingworks fine...
Any clue about the issue?
Ps sorry for my English Ă miss register and I'm on the USA community. Kiss from Switzerland 🇨đź‡
Model: R6120|AC1200 Dual Band WiFi Router, RAX40|Nighthawk AX4 4-Stream WiFi Router
- RickSwiDec 03, 2021Aspirant
Hi thanks for asking,
Yes I made progress on my trouble shooting. It isn't fixed yet but I'm pretty sure that the wire present a defect. Indeed, old R6120 is using only 4 of the 8 wires in the RJ45 plug (lucky or not... those are working fine...)
New model RAX40 is using the full rj45 8 cables.
So, my guess is one of the wire might present a trouble in the connection or a wire is broken.
- FURRYe38Dec 03, 2021Guru - Experienced User
Swap out the cabling. CAT6 LAN cable is recommended.
