JoeChillers
Feb 06, 2021Aspirant
No Internet Connection after Factory Reset
About a month ago, I bought a router to hook up to my modem. I used the Nighthawk app to help hook up the router and give off internet. The router worked well at the time. Just now I had to reset my ...
- Feb 07, 2021
try factory resetting both the router and the modem.
Feb 07, 2021Guru - Experienced User
What modem do you have?
You have the rax40?
- JoeChillersFeb 07, 2021Aspirant
Yes, the model is the RAX40
- plemansFeb 07, 2021Guru - Experienced User
ARRIS Touchstone CM8200
