JoeChillers's avatar
JoeChillers
No Internet Connection after Factory Reset
About a month ago, I bought a router to hook up to my modem. I used the Nighthawk app to help hook up the router and give off internet. The router worked well at the time. Just now I had to reset my ...
  • plemans's avatar
    Feb 07, 2021
    try factory resetting both the router and the modem.
