JoeChillers
Feb 06, 2021Aspirant
No Internet Connection after Factory Reset
About a month ago, I bought a router to hook up to my modem. I used the Nighthawk app to help hook up the router and give off internet. The router worked well at the time. Just now I had to reset my ...
- Feb 07, 2021
try factory resetting both the router and the modem.
JoeChillers
Feb 07, 2021Aspirant
After following your instructions, I tried to connect to my network, and it still gave me the same result:
No Internet, secured.
Feb 07, 2021Guru - Experienced User
