WimD
Oct 08, 2019Initiate
No internet connection on 2.4 G network
I notice a strange behaviour on my 2.4G network. Not all devices conected (mix of smarthphone and laptop) can connect to the internet using the 2.4G network. However if I switch on the same devic...
Oct 08, 2019Guru - Experienced User
You listed the R7000 as your router. Is this correct?
What firmware are you on? If you read the forums there's been many issues with firmware on this device. the most stable firmware so far has been the .42 firmware. if you're on a newer version, I'd recommend downgrading to earlier version. Make sure to do it over a hardwired connection and to reset afterwards. this'll give you the best results. You can get the older versions under the downloads section of the support site. Its under +view previous versions
https://www.netgear.com/support/product/r7000
Your other option that you could try would be to just factory reset the device with the current firmware and see if it was an issue from upgrading.
- WimDOct 12, 2019Initiate
Thank you.
Changing to an older version did not help.
I went for a hardreset of my router and also the TP link extender.
All works fine again.
