bmoore31480
Jan 06, 2021Tutor
No internet connection when trying to set up new AX12 Router
Router is a AX12 Nighthawk "Renewed" purchased from Amazon Modem is Netgear CM1200 purchased brand new Connecting router with Cat8 cable Cox internet I purchased my router "renewed" from amazo...
- Jan 06, 2021
A couple things.
1. the cm1200 has 4 ethernet ports. But for most ISP's, you can only connect 1 device to it because they only allow 1 public ip address.
2. lets get the cm1200 working and the rax120 connected to it with hardwired connection. Then we'll work on the wireless. 1 problem at a time. (you can always check if the wifi on/off button got it, push and hold it for 2 seconds)
3. Try this:
power off the modem and the router. unplug everything from both, even coax from modem. wait 2 minutes.
connect coax back to modem and power it on. wait several minutes for it to fully boot.
plug port 1 from modem into wan port on router. turn the router on.
give the router several minute to fully boot.
connect a pc/laptop to one of the lan ports on the router. attempt setup on it.
bmoore31480
Jan 06, 2021Tutor
Thank you for the response and help. I will try that when I get home this afternoon and give you an update.
bmoore31480
Jan 06, 2021Tutor
So I followed your advice and it worked perfectly!!! The router is now working great and my internet speed is averaging around 560 mbps. Thank you again so much for the help!!!!
- plemansJan 07, 2021Guru - Experienced User
glad it worked!
Let us know if you have further issues
