bmoore31480
Jan 06, 2021Tutor
No internet connection when trying to set up new AX12 Router
Router is a AX12 Nighthawk "Renewed" purchased from Amazon Modem is Netgear CM1200 purchased brand new Connecting router with Cat8 cable Cox internet I purchased my router "renewed" from amazo...
- Jan 06, 2021
A couple things.
1. the cm1200 has 4 ethernet ports. But for most ISP's, you can only connect 1 device to it because they only allow 1 public ip address.
2. lets get the cm1200 working and the rax120 connected to it with hardwired connection. Then we'll work on the wireless. 1 problem at a time. (you can always check if the wifi on/off button got it, push and hold it for 2 seconds)
3. Try this:
power off the modem and the router. unplug everything from both, even coax from modem. wait 2 minutes.
connect coax back to modem and power it on. wait several minutes for it to fully boot.
plug port 1 from modem into wan port on router. turn the router on.
give the router several minute to fully boot.
connect a pc/laptop to one of the lan ports on the router. attempt setup on it.
bmoore31480
Jan 07, 2021Tutor
So I followed your advice and it worked perfectly!!! The router is now working great and my internet speed is averaging around 560 mbps. Thank you again so much for the help!!!!
Jan 07, 2021Guru - Experienced User
glad it worked!
Let us know if you have further issues
