hossmail's avatar
Dec 13, 2022
No internet with new modem rax200
So i upgraded my modem, contacted my ISP to activate, but my rax200 shows as No Internet Connected, even though all is connected and activated correctly.  What gives? I contact netgear support.  T...
  • hossmail's avatar
    hossmail
    Dec 17, 2022
    Good news.  Got it working.  Thanks to all above posts on how to do it.  Here is a quick summary of the issue and what was done to resolve:
    Issue:
    After activating new cable modem (Motorola MB8611) with ISP, my Netgear RAX200 router was not passing internet via wireless nor hardwire connection.
    Resolution steps:
    1- Power off RAX200 router
    2- Activate modem with ISP (DO NOT CONNECT TO ROUTER YET)
    3- Confirm modem internet connectivity via hardwire connection to pc
    4- Power off modem
    5- With both modem and router powered off, connect the internet output cable to the internet in-port on the router
    6- Power on the modem ONLY
    7- Wait about 5 mins
    8- Power on router
    9- Wait about 5 mins
    -END   This process worked.
    BONUS:
    For me, i upgraded my speed plan with ISP.  The modem is for 2.5gbps, so I updated the router setting to activate it.  In the router settings interface, I went to Internet - Selected the middle option Multi-Gig Port (2.5/1gbps).  Apply   -  This initiated a router reboot. Then quickly connected the internet output cable to the 2.5ghz port on the opposite side of router, and after a few mins, all worked fine.  My internet speed increased as desired.
    Thank you everyone for your help!!!
