Kasey-K
Nov 07, 2022Aspirant
no Repeater mode? RAX49 routers (house-to-house wifi)
I'm a lucky man. Got two houses on a street located 500 feet apart. Been shooting a Wi-Fi beam from house #1 downhill to house #2 for many years now; just bought TWO Nighthawks to "upgrade" my system...
Nov 07, 2022Guru - Experienced User
Let's get something understood, for NG routers, "Bridge" mode is a wireless "bridge" mode that makes the router into a wireless client and makes it connect wirelessly to a host wifi signal thus any ethernet devices can connect to this router and get services. No additional wireless or broadcasts are seen in this "Bridge" mode.
"Repeater" mode, when seen on those models that support it, connects to a host wifi signal then re-broadcasts that signal for other wifi devices to connect too and ethernet devices can connect as well in this mode.
If you don't see Repeater mode under Advanced tab/Router Mode section or mentioned in the user manual, then this model doesn't support this mode.
Kasey-K
So do I even need a Router (with repeater mode included as a feature), stationed at house # 2. Or do I simply need a good-quality Wifi extender unit?
it seems like those are my two options:
1) router with repeater mode
~ OR ~
2) a Wifi extender
any comment about the pro's and con's of either move?
- michaelkenwardNov 07, 2022Guru - Experienced User
That could be down to personal preference and budget.
Are you convinced that you can get a wifi signal to travel between the two buildings? 500 feet is a heck of a stretch for wifi. That is about twice the range I have seen quoted for domestic kit.
It may be that you need something a bit fancier than a consumer grade extender.
- Kasey-KNov 07, 2022Aspirant
as I stated in initial posting, I have been sending wifi house-to-house successfully for years. Now that being said, I am "helping" a bit with low-loss, minimal-length cables connected to high-DBI-gain external, directional antennae aimed directly between point A & B. I've even experimented with 4 watt and 5 watt amplifiers.
However the new RAX 49 is sending a decent signal down the hill, with NO amplification devices added. It helps that there is not a single tree or shrub in the way of line-of-sight connectivity.
As I want to have Ethernet connected devices AND Wifi signal in house #2 it seems that Bridge is not an option.
oops typo. 4 watt and 8 watt amplifiers. not 5 watt.
