brado77
Apr 15, 2021Star
No trace of Wifi6 networks on Nighthawk RAXE500
I just bought a new NETGEAR Nighthawk RAXE500, set it up, 6G Wifi networks (regular and guest) are enabled and SSID broadcasting, and there's no trace of these Wifi 6 networks anywhere. I've got an i...
HarrySmooth
Nov 12, 2021Tutor
I just bought a new NETGEAR Nighthawk RAXE500, to replace my Nighthawk AX8 ,RAX80 which just stopped working! I am on Spectrums Highest Speed Internet available here, and was getting around 550-650mbps coming into the router, and USED to get anywhere from 400-550mbps on the Download Side coming out of the Router on the 2.4ghz Band.
After installing this new RAXE500, I’m STILL getting well over 650mbps coming into the router but now I can’t even break 100mbps coming out of the router (2.4ghz band) but I can squeeze upwards of around 350-400 mbps on the 5ghz Band!
I’m no Stranger to routers and networking and have ALWAYS used Netgear, because I KNOW Netgear, and they have always treated me well.
But I can’t figure out this Drop in signal!
After trying all the “Tweeks” I know to do, it’s still slow as molasses!
I called Geek Squad, and they’re sending me a Replacement Router, so we’ll see if I just got a Lemon or I’m missing something in setup!
I’ve set up so many Netgear routers I can do it in my sleep… But maybe this new 6E band crap has some settings I’m not familiar with….
Any Ideas? Anyone else run across this DRASTIC Signal Drop after installing this thing?
Any comments, advice etc would be deeply appreciated!!!
Thank you!!!
Harry
Thank you!!!
Harry
tonydi
Nov 12, 2021Luminary
What device are you using to test speeds?
- HarrySmoothNov 12, 2021Tutor
