brado77
Apr 15, 2021Star
No trace of Wifi6 networks on Nighthawk RAXE500
I just bought a new NETGEAR Nighthawk RAXE500, set it up, 6G Wifi networks (regular and guest) are enabled and SSID broadcasting, and there's no trace of these Wifi 6 networks anywhere. I've got an i...
Kolich69
Nov 17, 2021Aspirant
Hello to all.
I have win11(latest with all updates)
Intel Killer 6E AX1675x(based on the chip intel AX210) with latest drivers from intel web-site
my laptop clevo x170KM-G with latest bios
router raxe-500 with latest stable firmware
I see JUST 2.4GHZ and 5GHZ networks, what the problem and how to solve im really do not know, wasting time within few weeks....(((((
Anybody who can help me? Thank you.
- Kolich69Nov 17, 2021Aspirant
i mean i do not see wifi network 6GHZ ((((
- tonydiNov 17, 2021Luminary
If you go into the Web UI for the router and click the Advanced tab, then click Advanced Setup and Wireless Settings and then scroll down to Wireless Advanced Settings (6GHz a/n/ac/ax) is the 6GHz Enable Wireless Router Radio checked?
At one point that setting became disabled for some reason and I never though to look there.
If it's enabled, have you tried doing a factory reset on the RAXE500?
All networks Enabled.
I takes 1000 times factory reset, but this doesnt work(((( i really so tired(((
