brado77
Apr 15, 2021Star
No trace of Wifi6 networks on Nighthawk RAXE500
I just bought a new NETGEAR Nighthawk RAXE500, set it up, 6G Wifi networks (regular and guest) are enabled and SSID broadcasting, and there's no trace of these Wifi 6 networks anywhere. I've got an i...
tonydi
Nov 17, 2021Luminary
If you go into the Web UI for the router and click the Advanced tab, then click Advanced Setup and Wireless Settings and then scroll down to Wireless Advanced Settings (6GHz a/n/ac/ax) is the 6GHz Enable Wireless Router Radio checked?
At one point that setting became disabled for some reason and I never though to look there.
If it's enabled, have you tried doing a factory reset on the RAXE500?
Kolich69
Nov 17, 2021Aspirant
All networks Enabled.
I takes 1000 times factory reset, but this doesnt work(((( i really so tired(((
- tonydiNov 17, 2021Luminary
Do you have some variation of the Killer Control Panel installed? I've seen a lot of odd stuff with other routers and gateways because of setting in there. In fact, I now only use the actual drivers for any "Killer" card and avoid all of the other junk.
The other issue is that the card you have isn't exactly the same as the AX210 card that most of the rest of us are using. Since your card uses a completely different driver bundle it's hard to say if that's the problem or not.
- FURRYe38Nov 17, 2021Guru - Experienced User
I can see the 6Ghz SSID from my RAXE500 with a Intel AX210 PCI card all day long. Old and new FW. Problem is that it won't connect with WPA3 enabled on this router, while same care CAN connect to a different model NG router with WPA3 enabled.
- Kolich69Nov 17, 2021Aspirant
FURRYe38 wrote:I can see the 6Ghz SSID from my RAXE500 with a Intel AX210 PCI card all day long. Old and new FW. Problem is that it won't connect with WPA3 enabled on this router, while same care CAN connect to a different model NG router with WPA3 enabled.
i dont see 6ghz network with wpa or open(((((( yes i already installed this beta version of firmware....
tonydi wrote:Do you have some variation of the Killer Control Panel installed? I've seen a lot of odd stuff with other routers and gateways because of setting in there. In fact, I now only use the actual drivers for any "Killer" card and avoid all of the other junk.
i think chipset are same, just drivers different or may be something else......
yes i have installed killer control center, because without control center killer not a killer :)
I'd look through the control center and see if anything related to 6GHz pops up.
And during the early days of the RAXE500, lots of people with AX210 (not AX1675x) cards found that their particular cards didn't work on 6GHz. We chalked that up to there being only non-Intel vendors selling it and some were thought to playing fast and loose with the internals and slapping the AX210 sticker on them. So it wouldn't surprise me if there were issues with AX1675x cards too.
