momalley
Jan 12, 2022Follower
no WiFi internet connection
power light on - internet light is flashing fast - white light, no 2.4 or 5 GHz lights
reset 3x times
Try pulling the power adapter from the wall out let after pressing the reset button for 10-15 seconds then release.
Netgear has set up a community forum specifically for the NightHawk Router products:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
Thank you. - plemansGuru - Experienced User
are you able to access the router through the browser?
Did the wifi on/off button get hit? Push and hold it for 2 seconds.
