Dragonlady66
Apr 24, 2024Aspirant
No wifi range wifi 6
I have wifi but it is not stable. I have NO access to the modem because our company went to fiber and locked the modem in a box {no customer has access to the modems now as they say it is proprietary...
- May 02, 2024
Finally I can reply to let yall know where I am. Got the tech to come here, tested everything, all was fine, I upped my net speeds, still no help at all. Last thing at this point is assume maybe my MSI is too old {3} and see about getting it replaced soon. Thank you guys for the help. Sorry I don't have better news.
Apr 24, 2024Guru - Experienced User
So need more details here.
What NG router model are you referring too?
Fiber ISPs use ONTs, not modems.
Who is your ISP?
30 feet is kinda far for good signal connection and operation for a connected device. Especially if building materials are in between the router and your wifi device.
Dragonlady66
It says AX3600. There is nothing in the way. It is down a clear hallway in direct line. The laptop acts up with the "no internet connection" even 6 ft away from the router
- michaelkenwardApr 24, 2024Guru - Experienced User
Dragonlady66 wrote:
It says AX3600.
What says that? A label on the thing?
It isn't the model number, That could be something like RAX41 or MR80.
- Dragonlady66Apr 24, 2024Aspirant
Sorry, yes, RAX41-100NAS
- FURRYe38Apr 24, 2024Guru - Experienced User
Is this the only device that does this?
Do other devices see same behaviors?
Only other device is my phone. It seems to have problems if I leave the living room where the router is
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
