Dragonlady66
Apr 24, 2024Aspirant
No wifi range wifi 6
I have wifi but it is not stable. I have NO access to the modem because our company went to fiber and locked the modem in a box {no customer has access to the modems now as they say it is proprietary...
- May 02, 2024
Finally I can reply to let yall know where I am. Got the tech to come here, tested everything, all was fine, I upped my net speeds, still no help at all. Last thing at this point is assume maybe my MSI is too old {3} and see about getting it replaced soon. Thank you guys for the help. Sorry I don't have better news.
Apr 25, 2024Guru - Experienced User
Have them run speed tests with you and your PC connected to there ONT, then do same thing with the RAX online so they can see. Also check some web sites as well. Be sure all is working to your expectations before the tech leaves.
Good Luck.
Dragonlady66
May 02, 2024Aspirant
