ckiori88
Mar 06, 2021Aspirant
Nokia 3 can not find Wifi SSID after upgrading the firmware 1.2.0.16 of RAX120
As title, I have a problem about that but it was work for the iphone series. I can sure my Nokia-3's work well to find SSID and connect the wifi with old firmware version of RAX120. Even the con...
- Mar 08, 2021There seems to be a fault with dchp I dont know if Netgear are aware things you can do is 1st try on your phone making a static ip when connecting to wifi. 2nd pin hole reset or roll firmware back to .136 then reset again. Also forget the wifi ssid on your phone and try again
thehypnootoad
Mar 08, 2021Luminary
- ckiori88Mar 13, 2021Aspirant
Thank you for the reply.
I just only roll firmware back to 1.2.0.136 and then my Nokia 3 work well to find the SSID of RAX120 as the same as the past.
I don't know what's the different firmware version but it was wrear thing after upgrade.
