GrahamA836
Jan 01, 2024Follower
Nord VPN for RAX1-100NAS
What needs to be done to install Nord VPN on my new router. I am completely new to this personal owned router. Seem to work much better than IPS supplied router. What to install VPN for protection.
Jan 02, 2024Guru - Experienced User
Most of these vpn's you either install to your router or all your devices.
If you want to install it to your router, it has to be a compatible one. that router isn't compatible.
so you'd either need to install nord to each device individually or buy a router that is compatible.
Check nord's site for compatible routers as its third party firmware and not supported on official forums.
