thinksinc
Oct 02, 2019Apprentice
Not achieving Wifi 6 speeds with RAX200 on iPhone 11 or Intel Wifi 6 laptop card
I just received and set up my RAX200, and am not getting expected WiFi 6 speeds on my (only) WiFi 6 capable devices: an iPhone 11 Pro Max and an Intel WiFi 6 card in my Dell XPS 15. I was previou...
thinksinc
Oct 03, 2019Apprentice
Thanks for the advice. I'm not sure how to enable 160hz channels, I don't see much online related to that or how to enable it.
For channels, I'm currently running:
WiFi (2.4Ghz): Auto
WiFi (5Ghz 1): Channel 44 (from a choice of 36, 40, 44, 48, 52, 56, 60,64)
WiFi (5Ghz 2): Channel 100 (from a choice of 100. 104, 108, 112, 116, 120, 124, 128)
I don't see the option to select anything around 160hz.
I'm running the latest driver for the Intel AX200 card as of today.
Altsai
Oct 04, 2019NETGEAR Expert
thinksinc wrote:Thanks for the advice. I'm not sure how to enable 160hz channels, I don't see much online related to that or how to enable it.
WiFi (2.4Ghz): Auto
>>>>>>>>> iphone 11 only support 2x2 up to 80MHz band so the max link rate is 1200Mbps
>>>>>>>>> regarding 160 or 80Mhz selection, you will find "the mode" up to xxxMbps. if you see up to 4800Mbps, the bandwidth is 160MHz. if 2400Mbps, it's 80Mhz
