glveale
Dec 23, 2022Follower
Not enough ethernet ports on router
I have a Nighthawk RAXE500 router. It only has 5 ethernet ports. How can i add ethernet ports to the roouter?
Buy adding a non managed Gb switch that come in port counts of 5 all the way up to 52 ports if you really need that many?
NG GS 105/8 or 16 series would work for you.
Let get you to the right forum section as well. 🙄
Start here:
They start at around £$€20.
Buy more ports than you think you need for now.
