jhu_5
Aug 17, 2020Tutor
Not getting full gigabit speeds with Netgear Nighthawk AX5400
Upgraded to Xfinity 1000 Mbps/35 Mbps plan recently. Had comcast guy fix the connection and could reach 900 Mbps from the modem (Arris T25 with Docsis 3.1) directly. Old router from Linksys ES850...
jhu_5
Aug 17, 2020Tutor
Direct from modem speed is around 900 Mbps, same PC and same wired connection.
I did upgrade FW when I installed the new netgear router. Will try factory reset tonight.
Thanks,
jhu_5
Aug 17, 2020Tutor
Looks cool now, after factory reset and upgrade FW again. I did reload the config I saved.
From QOS speedtest, could reach 440/42.
From iPhone, 553/41.
Thanks for the help.
