Drumman3
Jan 21, 2023Aspirant
Not getting full internet speed over Wifi
I purchased the RAX120 router because lots of reviews and post I’ve seen say this router has over a Gig throughput over Wifi, I have Gig+ xfinity internet, the internal speed test shows I’m getting be...
Drumman3
So the people I’ve seen say they are getting over a gig have the right unit to test the speed or they did it at the right time and the environment was perfect or they are lying?
microchip8
Jan 21, 2023Master
Could be both...
- Drumman3Jan 21, 2023AspirantSo, the only way to find a router to give me a gig output is to buy and test, can’t listen to the reviews?
Which stinks because I bought this router off eBay and it seems to be working just fine, it’s brand new just not getting the output I am looking for.- michaelkenwardJan 21, 2023Guru - Experienced User
Drumman3 wrote:
So, the only way to find a router to give me a gig output is to buy and test, can’t listen to the reviews?What do you do that needs Gigabit Wifi?
How many Wifi clients do you own that are that fast?
- Drumman3Jan 21, 2023AspirantAmazon FireStick sideloading apps. The faster the internet the less problems with buffering. May just buy the adapter to use it hardwired.
- microchip8Jan 21, 2023MasterYou're not getting the "output" you're looking for because your test client device (iPhone 11) can't handle more than what you already get (~800 Mbps). It's a 2x2 MIMO device. As mentioned, you not only need the right equipment but also an ideal setting to get even close to the advertised speeds
