tv7785
Nov 30, 2019Follower
Not getting WiFi speed
So my AT&T plan is 1000mbps. My wired connection from the BGW210 modem is around 800-900mbps but when I connect to the RAX40 I’m getting around 200-300.
Dec 01, 2019Guru - Experienced User
the BGW210 is a modem/router combo device. And att is horrible at enabling pass through mode/modem only mode on their devices.
you're basically in a double nat as well as there's the chance that the BGW210's own firmware is throttling the speeds.
https://kb.netgear.com/30186/What-is-Double-NAT
have you tried the RAX40 in AP mode? it disables router mode and you lose some functions but can fix the double nat issue.
