tv7785
Nov 30, 2019Follower
Not getting WiFi speed
So my AT&T plan is 1000mbps. My wired connection from the BGW210 modem is around 800-900mbps but when I connect to the RAX40 I’m getting around 200-300.
GabboCH
Dec 04, 2019Apprentice
What transfer speed are you getting if you run the Nighthawk App "Speed Test" from teh RAX40?
This feature runs on the router so should give you an indication of the actual speed between the modem/router & RAX40.
Maybe worth to read some of the other RAX80/120 threads as there are other users reporting problems with LAN transfer speeds being halfed due to issues with QoS.
