RSHermann
Sep 26, 2022Tutor
Notebook doesn't see my network on an RAX20
I have a notebook with Windows 10. I have had to reset the notebook due to a bit locker issue but after the reset, this notebook now does not see the home network... at all. I have tried entering it ...
- Oct 13, 2022
Hello!
Solved when Windows ran a number of updates!!!
Thanks all!!
RSHermann
Sep 26, 2022Tutor
Addendum; The notebook sees all the neighborhood networks. The notebook has connected successfully to the home network for the past couple of years with no issues prior to the Bit Locker issue.
michaelkenward
Sep 29, 2022Guru - Experienced User
I'm a bit lost. (Easily done.) Do you still have the issue described in your first message?
How do you connect the laptop? Wired or wifi?
What do you see in the way of messages when you try to get on to the network?
Have tried throwing the Windows Network Troubleshooter at it?
Windows likes to protect us from new networks that might be evil. In reality, it sometimes blocks safe networks.
One thought is that you could tell Windows that you are on a "private network".
- Network and Internet settings
- Network Status
- Change Connection Properties
- Network Profile
- Private
I'm told that this is rubbish advice. But it has worked for me and others in the same boat.
- RSHermannOct 13, 2022Tutor
Hello!
Thanks all!!
- michaelkenwardOct 14, 2022Guru - Experienced User
RSHermann wrote:
Hello!
That's good. Another router found not guilty.
