Razor512
Dec 12, 2023Prodigy
NOTICE - RAXE500 Firmware Version 1.2.13.100 Released - DO NOT USE!!!
Bug Fixes: 12/12/2023
Fixes the issue where Anywhere Access doesn’t work when Web Services Management is turned on.
Fixes the issue where the on-board log doesn’t automatically clear after logs...
Killhippie
Dec 20, 2023Prodigy
Ive noticed on this version I'm not getting the usual DoS attacks and port scans, tried a factory reset and its still the same all I get is DHCP lease updates. I wasn't looking for option 61 at the time but maybe look under advanced-setup internet- choose internet doesn't require login use DHCP then at the bottom of the same page look to see if option 61 appears, this has worked for some users after recent updates, If not revert to the previous version. Netgear will need new firmware quickly in 2024, it seems, how can they break so many things is beyond me. <sigh>
hodoknaru
Dec 19, 2023Initiate
A heads up/ caution for all of us who uses their RAXE500 with an ISP who requires DHCP choice 60 or 61. The state-of-the-art firmware 1.2.13.One hundred eliminates those options from internet setup that means you won't be able to connect. This stops the router from running with Sky net in the uk.
