Razor512
Dec 12, 2023Prodigy
NOTICE - RAXE500 Firmware Version 1.2.13.100 Released - DO NOT USE!!!
Bug Fixes: 12/12/2023
Fixes the issue where Anywhere Access doesn’t work when Web Services Management is turned on.
Fixes the issue where the on-board log doesn’t automatically clear after logs...
JazzerBazza
Jan 14, 2024Initiate
My FTTP broadband with Sky suddenly stopped working on Friday. After two hours of messing about I eventually found it was due to the router doing an auto update, resulting in losing DHCP option 61. Luckily I’ve been able to roll back and get it working again.
I reached out to tech support to let them known and ask if option 60 and 61 will be included in future firmware updates but they couldn’t give me a definite answer.
This has me now questioning if I want to keep my RAXE500. It’s a bit of a dilemma because I actually like the performance of the router so far.
I want reassurance that it is future proof with the ability to receive software updates which don’t break it for me. However, I purchased it from Amazon in the Black Friday sale and I have until 31st Jan to return it. I’m considering the Asus GT-AXE11000.
In the mean time I’ve just sent another response to support asking if it’s possible to receive the beta update.
Jan 14, 2024Guru - Experienced User
We've passed this on to NG for review in a bug report. No idea IF or WHEN the fix will be put forth.
I recommend that you check on the beta as mentioned others have asked about a beta and seemed to get users working again.
Or use the RAXE500 with prior working version of FW. If it was working well on that version, then keep it. You don't have to update. If it works, don't fix it.
Will keep an eye on this.
Thanks.
- FURRYe38Jan 19, 2024Guru - Experienced User
NOTICE:
With recent issues, problems and experiences seen this version of FW, I recommend users avoid this version of FW and revert FW on there routers back to previous version: v1.0.12.96
https://kb.netgear.com/000065500/RAXE500-Firmware-Version-1-0-12-96
I've asked NG to pull v.100 from public access as well.
NG will need to review all the problems and get them fixed from this version. Hopefully next version will be much better.
Thank you.
- FURRYe38Jan 25, 2024Guru - Experienced User
FYI, got word that NG should be putting for the new FW with fixes for the DHCP option and VPN issues in near future.
