Razor512
Dec 12, 2023Prodigy
NOTICE - RAXE500 Firmware Version 1.2.13.100 Released - DO NOT USE!!!
Bug Fixes: 12/12/2023
Fixes the issue where Anywhere Access doesn’t work when Web Services Management is turned on.
Fixes the issue where the on-board log doesn’t automatically clear after logs...
Jan 19, 2024Guru - Experienced User
NOTICE:
With recent issues, problems and experiences seen this version of FW, I recommend users avoid this version of FW and revert FW on there routers back to previous version: v1.0.12.96
https://kb.netgear.com/000065500/RAXE500-Firmware-Version-1-0-12-96
I've asked NG to pull v.100 from public access as well.
NG will need to review all the problems and get them fixed from this version. Hopefully next version will be much better.
Thank you.
Jan 25, 2024Guru - Experienced User
FYI, got word that NG should be putting for the new FW with fixes for the DHCP option and VPN issues in near future.
