VAHokies
Jan 27, 2024Guide
Noticed it 3 days ago
I am having the exact same problem. Noticed it 3 days ago.
When I successfully login to 192.168.1.1 I am redirected to https://accounts-qa.netgear.com/error?redirectUrl=http:%2F%2F192.168.1.1%2Fge...
VAHokies
Jan 27, 2024Guide
When I successfully login to 192.168.1.1 I am redirected to https://accounts-qa.netgear.com/error?redirectUrl=http:%2F%2F192.168.1.1%2Fgenie_redirect_SSO.htm&serial_num=5G....
When I disconnect from the internet, I can login to 192.168.1.1 just fine
Looking at the web traffic I see JavaScript code redirecting from 192.168.1.1 to https://accounts-qa.netgear.com/error?redirectUrl=http:%2F%2F192.168.1.1%2Fgenie_redirect_SSO.htm&serial_num=5G....
I disabled JavaScript and I login but then I just get a blank screen.
michaelkenward
Jan 27, 2024Guru - Experienced User
Same RAX50v2 router? Firmware version?
Browser? (These are ever changing animals.)
Operating System? (Windows can do strange stiff.)
- VAHokiesJan 27, 2024Guide
Same router RAX50v2 / can't get firmware version since can't login
Tried and failed with:
Windows 10(Chrome)
Windows 10(Edge)
Linux Mint(Firefox)
Android(Chrome)- VAHokiesJan 27, 2024Guide
I reset to factory default and redid my settings and I still have the same problem.
I don't believe in coincidences; I think Netgear made some change in the last few days that is effecting rax50v2 routers.
- VAHokiesFeb 14, 2024Guide
I had the exact same problem with my RAX50v2, I noticed it on 1/24/2024.
I tried clearing the logs and then resetting the router - neither worked.
I have since confirmed that firmware update 1.1.4.28 caused this problem.
To confirm this, I reverted my router to firmware 1.1.3.18 and everything worked fine - I could login just fine.
Then I updated to firmware 1.1.4.28 and the problem was back - unable to login.
