GabboCH
Oct 30, 2019Apprentice
NTP - Time Server Sync Frequency
Pfter checking my router logs, it appears that the router is synchronising the time with the Netgear NTP server every 30minutes & sometimes only 5minutes after a sync. Is this expected ?? 1 time...
schumaku
Nov 03, 2019Guru - Experienced User
GabboCH wrote:Pfter checking my router logs, it appears that the router is synchronising the time with the Netgear NTP server every 30minutes & sometimes only 5minutes after a sync.
No, completely wrong. The NTP time sync happens every time the router does connect to the Internet successfully. Best guess, you use an Internet onnection requiring authentication, and the router is configured with a Idle Timeout and Connect on Demand. This is wht kills your Internet connection, and when the next time Internet connection is required, the router does dial-up, and the NTP time sync follows.
- AutomanNov 04, 2019Apprentice
My RAX80 does that also.
Every 24hrs and on power up would be a more normal interval to check the RTC is accurate.
I did report this issue a month or so ago but like most problems with the RAX80 they don't get fixed.
My one is no longer in use and I have gone back to my old one.
- schumakuNov 04, 2019Guru - Experienced User
Automan wrote:My RAX80 does that also.
If you get the pairs of "[Internet connected]" and "[Time synchronized with NTP server]" your router does (or did) connect to the Internet only if traffic is requesting it. Otherwise the connection does timeout as configured. The reason why it does happen - unless you have a router that is crashing and rebooting - is very clear, and not an issue.
Automan wrote:Every 24hrs and on power up would be a more normal interval to check the RTC is accurate.
That's what is implements, and what Netgear routers commonly do:
[Time synchronized with NTP server] Saturday, August 03, 2019 12:51:46[Time synchronized with NTP server] Saturday, August 04, 2019 12:51:47
[Time synchronized with NTP server] Saturday, August 05, 2019 12:51:49
[Time synchronized with NTP server] Saturday, August 06, 2019 12:51:53
[Time synchronized with NTP server] Wednesday, August 07, 2019 12:51:53
[Time synchronized with NTP server] Friday, August 16, 2019 12:52:08- AutomanNov 04, 2019Apprentice
Seems pretty stupid to me to keep making requests on time servers that often.
Do the internals clocks really need setting that often?
Still their product in recent times have been pretty poor.
- GabboCHNov 04, 2019ApprenticeMy internet is a permanent cable connection & at 7pm at night I would expect the connection to the internet to be running heavily with Sonos, YouTube, kids iPad's, Netflix, Xbox etc.
The household uses internet heavily & has lots of connected devices which was the main reason for wanting the Wi-Fi6 router.
I'll check my modem/router logs tonight to see if it is shows any IP reassignement or internet connection information.
My modem is also assigning the network IP addresses so the RAX80 is in access point mode.
I found a similar post in an old forum for the R8000 router & there was an reply from a Netgear support saying that a time sync every hour was a function of the router.- AutomanNov 04, 2019Apprentice
My one does it more than every hour but it can't even manage to save device type icons plus of course their android app uses diffent device icons. One would think it was designed / programmed by two teams with different product specifications.
My latest log.
[LIST]
[Admin login] from source 192.168.1.83, Monday, Nov 04,2019 20:13:48
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:13:34
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:13:04
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:12:32
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:12:01
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:11:30
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:10:57
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:10:26
[Time synchronized with NTP server] Monday, Nov 04,2019 20:10:26
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:09:58
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:09:17
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:08:45
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:08:15
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:07:43
[DHCP IP: (192.168.1.80)] to MAC address 70:EE:50:29:35:0C, Monday, Nov 04,2019 20:07:18
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:07:12
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:06:41
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:06:10
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:05:37
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:05:07
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:04:36
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:04:05
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:03:34
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:03:02
[Time synchronized with NTP server] Monday, Nov 04,2019 20:02:55
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:02:31
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:02:00
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:01:30
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:00:59
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 20:00:28
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:59:58
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:59:26
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:58:55
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:58:27
[DHCP IP: (192.168.1.80)] to MAC address 70:EE:50:29:35:0C, Monday, Nov 04,2019 19:58:15
[Time synchronized with NTP server] Monday, Nov 04,2019 19:58:10
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:57:53
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:57:12
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:56:40
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:56:09
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:55:38
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:55:07
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:54:36
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:54:08
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:53:32
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:53:01
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:52:31
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:51:56
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:51:29
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:50:54
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:50:17
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:49:46
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:49:18
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:48:44
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:48:17
[DHCP IP: (192.168.1.80)] to MAC address 70:EE:50:29:35:0C, Monday, Nov 04,2019 19:48:12
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:48:12
[Time synchronized with NTP server] Monday, Nov 04,2019 19:47:54
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:47:42
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:47:11
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:46:39
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:46:10
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:45:38
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:45:07
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:44:39
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:44:03
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:43:33
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:43:02
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:42:31
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:41:43
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:41:22
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:40:51
[Time synchronized with NTP server] Monday, Nov 04,2019 19:40:25
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:40:20
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:39:49
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:39:18
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:38:47
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:38:16
[DHCP IP: (192.168.1.80)] to MAC address 70:EE:50:29:35:0C, Monday, Nov 04,2019 19:38:10
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:37:45
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:37:14
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:36:43
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:36:12
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:35:41
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:35:09
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:34:38
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:34:08
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:33:36
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:33:06
[Time synchronized with NTP server] Monday, Nov 04,2019 19:32:54
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:32:34
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:32:03
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:31:32
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:31:00
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:30:25
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:29:54
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:29:22
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:28:51
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:28:20
[DHCP IP: (192.168.1.80)] to MAC address 70:EE:50:29:35:0C, Monday, Nov 04,2019 19:28:07
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:27:36
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:27:04
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:26:33
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:26:02
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:25:31
[Time synchronized with NTP server] Monday, Nov 04,2019 19:25:24
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:25:00
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:24:28
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:23:57
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:23:26
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:22:55
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:22:24
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:21:53
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:21:21
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:20:50
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:20:19
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:19:48
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:19:18
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:18:50
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:18:19
[Time synchronized with NTP server] Monday, Nov 04,2019 19:18:18
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:18:16
[DHCP IP: (192.168.1.80)] to MAC address 70:EE:50:29:35:0C, Monday, Nov 04,2019 19:18:05
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:17:44
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:17:13
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:16:42
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:16:10
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:15:43
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:15:09
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:14:38
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:14:06
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:13:35
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:13:04
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:12:32
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:12:00
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:11:32
[Time synchronized with NTP server] Monday, Nov 04,2019 19:11:29
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:11:28
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:10:57
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:10:27
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:09:56
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:09:24
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:08:53
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:08:22
[DHCP IP: (192.168.1.87)] to MAC address A0:BB:3E:90:01:D7, Monday, Nov 04,2019 19:08:05
[DHCP IP: (192.168.1.80)] to MAC address 70:EE:50:29:35:0C, Monday, Nov 04,2019 19:08:03
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:07:52
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:07:20
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:06:52
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 19:06:15
[DHCP IP: (192.168.1.86)] to MAC address D4:38:9C:A0:17:DE, Monday, Nov 04,2019 19:05:45
[Time synchronized with NTP server] Monday, Nov 04,2019 19:02:54
[Admin login] from source 192.168.1.83, Monday, Nov 04,2019 18:59:39
[DHCP IP: (192.168.1.83)] to MAC address 7C:5C:F8:4B:90:1A, Monday, Nov 04,2019 18:59:06
[DHCP IP: (192.168.1.80)] to MAC address 70:EE:50:29:35:0C, Monday, Nov 04,2019 18:58:00
[DHCP IP: (192.168.1.85)] to MAC address 70:8B:CD:12:32:D4, Monday, Nov 04,2019 18:57:47
[DHCP IP: (192.168.1.84)] to MAC address 40:CB:C0:E2:32:98, Monday, Nov 04,2019 18:57:13
[Time synchronized with NTP server] Monday, Nov 04,2019 18:55:45
[Log Cleared] Monday, Nov 04,2019 18:54:36[/LIST]
Just the NTP requests, easier to read...
