perseid
Sep 24, 2022Aspirant
OFDMA for 5GHz/RAXE500
I just installed and manually set up the RAXE500 as AP in my LAN and so far so good. By default OFDMA is disabled for the 2.4 and 5GHz bands, will I get any benefit/harm by enabling it? Thanks
Sep 25, 2022Guru - Experienced User
Some see a benefit from other, others not as much.
Enable it and see how well it works for you.
https://www.smallnetbuilder.com/wireless/wireless-features/33222-does-ofdma-really-work-part-1
https://www.smallnetbuilder.com/wireless/wireless-features/33223-does-ofdma-really-work-part-2
perseid
Sep 25, 2022Aspirant
I'm using the 5GHz band with OFDMA enabled, so far so good, stable connection, however I cannot feel speed improvement
- plemansSep 25, 2022Guru - Experienced User
From everything I've read, you don't really notice much difference (if any). Speedtesting can show results but even that is variable.
