bluejway
Nov 20, 2022Aspirant
Office No Modem Just Ethernet Port on Wall
I tried to set up the Nighthawk AX12 in my university office. There’s no modem, just an ethernet cable coming out of the wall. I registered the AX12’s Mac Address with our university server as requir...
- Nov 21, 2022
While you will be under a double NAT, (no avoiding it in that case), make sure you give then the MAC address for the WAN port (available on the advanced tab of the router page).
Also, does the university heavily restrict network traffic, e.g., only allowing a small number of ports to be used, in addition to a restriction for a wide range of traffic types?
bluejway
Nov 21, 2022Aspirant
It's fixed
michaelkenward
Nov 22, 2022Guru - Experienced User
bluejway wrote:
It's fixed
Care to share how, so that you can help anyone else who turns up here with the same problem?
Did you follow the suggestion from Razor512?
