lucrabbit
Mar 04, 2021Guide
One week new RAX120 5G SSID disappeared
Title says it all. Did some search on the forum and found I am not alone. Did factory resetting, not using DFS etc Running the latest FW with all my devices on 2.4G. So frustrating! These days we r...
thehypnootoad
Mar 04, 2021Luminary
Is the firmware on .16 I also got this issue and still git many but try a pinhole reset for 10 secs if fails download previous firmware .136 and install that then after its all done reset again and fresh install no config file.
lucrabbit
Mar 04, 2021Guide
Thanks for the response. Yes the current FW is currentlly at .16. Upgraded to this version when I first got the router last week. It has been stable for the past week though. Already tried the factory reset etc. Will find the old FW and give it a try. Using an old 11N router now, in 2021....
- thehypnootoadMar 04, 2021Luminary
- lucrabbitMar 04, 2021Guide
Just downgraded to .136, the situation is the same (ch 153 now). 5G SSID is broadcasting but still couldn't see it under the list.....
Just found RAX120v2 under the support page. Well, that's going to be a differnet topic
- thehypnootoadMar 04, 2021LuminaryDid you do pinhole reset aswell ?
