WEAJMSW
Dec 17, 2022Follower
Only 1 device not connecting to R6700AX Nighthawk wifi router
ALL other devices (+20) in my home are connecting to my R6700AX and the 1 device (PC) that will not can see all other wifi networks in area including another wifi hub I have. Have tried to manually a...
Razor512
Dec 17, 2022Prodigy
We will need the model of the WiFi adapter of the PC that is having trouble connecting.
Beyond that, also check which channels the devices that the computer can't see are using. For example, if your smartphone can see all of the APs, then run an app like WiFi analyzer https://play.google.com/store/apps/details?id=com.farproc.wifi.analyzer
and then see if they have any channels in common. Often when a single device can't find an AP, it is typically due to something like it being an older WiFi radio that never went through the approval process to use DFS channels, thus APs using those channels, end up not being visible.
