DbleT
Nov 06, 2019Aspirant
Open Ports Win 10
Hello, new guy here who just recently purchased the RAX120. Today I visited Steve Gibson Research website and ran Shields Up to see my exposure to open ports. I had been there a long time ago when I ...
- Nov 12, 2019
Hi DbleT,
Thanks for getting back. I absolutely understand as it's never a bad idea to ensure your system is secured. At this time it doesn't seem like something to be concerned about. However, if you'd like for a support agent to look into this further for you, you may get in contact with our agents using the link below.https://www.netgear.com/support/default.aspx
Best regards,
Christian
DbleT
Nov 11, 2019Aspirant
Just thought I'd add that when you run the scan it shows open, closed and stealth ports (port scanners that a hacker might use can't "see" the ports as I understand it if they are in stealth mode). A long time ago when I used Zone Alarm Security Suite all my ports were in stealth mode. Hardly any are now since I use Malwarebytes and Windows Securtiy to keep my computer secure.
Christian_R
Nov 12, 2019NETGEAR Employee Retired
Hi DbleT,
Best regards,
Christian
